reply to farmallhal on SH alternator
Anonymous-0
Thank's for the response to my question on SH alternator. I would greatly appreciate if you would share with me your process of installing the Hitachi alternator on the SH. MY e-mail is on the post. Be waiting to hear from you. THANK'S for your help! This my tenth tractor I'm restoring, sure is a great hobby,really help's to have a place to ask questions, and get answer's.
IT is the same as a 10SI Delco
The S terminal is = to the #2 terminal on the Delco, and the I terminal is the same as the #1. S for sensor, I for indicator light.
Connect S to the big stud terminal, and the I to a diode, or 10 to 20 ohm 10 watt resistor, or a bulb type marker or instrument light. The other terminal of the diode/resistor/lamp goes to the coil side of the ignition switch. JimN
Don, I sent you my conversion file yesterday through your email address - please advise if you received it. Thanks, Hal.
