super m wires to plugs
jacxs11
i got new plugs and dis. cap now i dount know were they go on the dis. this is a 4 cilender
can any one help or show me a wireing dia.
Your firing order is 1-3-4-2. #1 is at the front.
The tower on the cap for #1 is normally at about 2 o'clock when viewed with the cap istalled. But strange things do happen, and it's worth the extra few minutes to verify that.
Pull your #1 spark plug and turn the motor until you can feel the air being force out of the plug hole. Turn it slowly from there (the handcrank sorks best for this) until you see the piston come up to the top of the cylinder. If you pull the cap at that point, the rotor button will be pointing to where your #1 plug wire belongs. Make a mark of some sort on the distributor body where the rotor is pointing. Put the cap back on, and the tower that is over your mark will be for #1.
From there, going around clockwise when facing the cap, attach the wires for 3,4 and 2 in that order.
I love pictures
i thank you guys very much the pic.
realy does it i wish when questions are asked we could always get pic.
thanks again
Jsck
