super c touch control hydraulic rebuild
Troy Hayward
New User
I have a super c that the hydraulic lift assembly is leaking fluid on. Was wondering if it is difficult to rebuild? It looks like a lot of small parts but I am mechanincly inclined. Does any one have any advice before I start?
If its leaking at the two pistons where the linkage is fastened you dont need to tear the unit apart. You can remove them and replace with the unit in place at least thats what i found on a SA replaced the o-rings and that stopped the leak.
