It can charge equally well at EITHER Pos or Neg ground,,,,,,,,,
Some VR's are labeled suitable for Pos or Neg ground, while others are specific for Pos or Neg ONLY,,,,,,,,,
If a genny is at opposite polarity from battery and tractor ran a while, it can damage VR,,,,
POLARIZE THE GENNY BEFORE YOU START IT this time after you swap battery Polarity
My Troubleshooting Procedure linked below in Para 5 tells how to determine if non charging is a Genny or a VR problem, check it out,,,,,
If battery polarity is swapped the coil leads (Unless a Mag) need swapped and ammeter leads also. She was originally Pos ground but maybe the coil and ammeter never were swapped in the first place if it got changed to Neg??????????
http://www.ytmag.com/cgi-bin/viewit.cgi?bd=farmall&th=665110
Headed out in RV to a Bluegrass Festival, 3 or 4 days of pickin my beginners banjo n jammin n bands n campfire BS at which Ive been accused of being a pretty good hand at lol See yall when I return
Ol John T and all
John Ts Troubleshooting
