IH power unit
ACSeppo
New User
Recently purchased a complete 4 cylinder power unit. Number stamped above mag reads UAAM 24, Casting on block 6791 DI, Very similar to the 113ci but the starter is on the right side below oil filter/housing, Any info on this would be appreciated Thanks
Thats where they put the starters. Those also turned backwards from the ones mounted on the bell housing. Wont work intill the fields are reversed.
It is a U-2 power unit, 113.1 cu in, 4 cylinder, 3" x 4" b & s, 22 hp @ 1800 rpm, 78 lb ft @ 1000 rpm torque, 5.23-1 compression, 675 lbs. Same basic engine as used in A and B tractors.
Harold H
