hydraulic and rear end fluid
jdetig1
what kind of fluid should i put in the hydraulic resivoir on my 1952 super m, ive heard of people putting 30 weight oil in them but idk. also what kind of fluid should i put in the rear end i was thinking like 80-90w. and i just rebuilt my super m so should i put any lead substitute in the gas or some mystery oil or seafoam or something or should i just put straight gas in.
for the rear end, 80-90wt gear lube is fine. it holds about 13 gallons, i generally wait till its on sale at the farm store and pick up some. teh 85-140 works good too. for the hydraulics, 30 wt is what was used in the belly pumps. i run hy-tran in the hydraulics on all mine, that way when hooking up to implements, its all the same fluid.
