Changing seat's on a Cub
darock
I would like to change the seat on my 51 Cub
From stock seat to the deluxe seat.
I was wondering how hard it is to change shifters
and how to remove the shifer knob????
You have to have a knob puller. That would be a hand, forearm, and attached muscels. The knob is not threaded. It's a push on -- pull off kinda deal.
As Wardner says, the knob just pulls off. You will also need a longer shift lever with the correct bend. There is a pin that holds the lever in. Remove this pin and lever and insert new lever, making sure end linds up in the rails, and reinsert the pin.
Harold H
Would probably just as easy and fast to switch the whole assembly out. Just changing the shifter can be a pain, but is doable. What it is, 6 or 8 bolts takes the whole top and all out? I changed the shifter on my Cub, with the same thing though, twice, and swapping thew whole top was by far easier.
