soybeanjoe
I rfecently puchased a '66 806D to add to our IH tractor collection. Tractor will also be used in the fall on an auger & possibly do some bush hogging with it as well.
The other day my son started it up & noticed a rumbling noise in the transmission. Sounds like gears tumbling, sort of like the rear end noise you hear in the Magnums but this is in the tranny. Noises seems most prevalent when the tractor is at an idle and goes away when the cluth is pushed in. You can near a change in sound when the TA is moved between HI & LO. Range & gear shift levers don't have any vibration in them
CIH service manager said it was common to hear some gear noise but our '66 1206 or '66 706 don't make this noise. Any suggestions as to what it may be?
TIA,
sj
TIA,
sj
