Ok, guess I'm kinda showing off. You would too after all that work. Finally finished my H. Rebuild the rear end, pto dogs sheared off, replaced with new spline type pto shaft, lower trans shaft, bearings, seals, galore. sand blast and paint from hydro pump back, installed 3 point hitch from Saginaw, sand blast and paint all sheet metal. sand blast, and refurb as seen buzz saw. It actually says "New Holland Machine Company, Combination saw" in the casting. This is a '47 H, but I think the rear is actually older. I haven't dug deep enough yet. New lights, lots of unmentionables.
Tractor going to show coming up july 10 to 12th, in Tunkhannock, PA. Buzz saw and antique 2 row corn planter (IH) is going with it. Looking forward to it!
See you there
Dan in PA
See you there
Dan in PA
