I-4 information
Anonymous-0
I'm looking at an I-4. It's in real bad shape. I was looking for rear wheels for it. They look like they used to be split rims. It has duals so I would like to find 4. Didn't know if wheels would fit off of a w4 or not. Also have the ser.# 16492 but don't know if they followed the rowcrop numbers or not. Is there a good place (other than right here) to find specs and info on I4s. Thanks
wheels off a W4 should fit, just got a pair for a freind of mine the best we could do was get a used set for $400. the 26" rims are an odd ball. brad new your looking at 400+ each.
Anderw
The I-4 originally likely had split rims for 24 inch tires. I have an I-6 and it has split rims and 24 inch tires. I think the I-4 would be the same, except the rims would be for a narrower tire. It's possible that one piece rims from a w-4 would fit, but you better measure first. I know that the hubs are different between the I-4 and the W-4. The I-4 has a solid cast disk hub, whereas the W-4 has a spoked hub that is a lot lighter weight.
