Cub 129 Drive Shaft Pin Problem
My cub cadet 129 hydrostatic stopped moving. I found that the drive shaft dowel pin had been sheared. When I got the drive shaft out of the tractor I found the old pin is completely stuck in there. I tried drilling it out but I don't have anything that will touch it. when I pound on it with a punch it doesn't move. Is it possible this was welded in there? All the ones I see on the internet have a hole where the pin fits in.
Thanks.
If it has been in there for this many years, you will need a press. If I remember correctly, this is a spiral roll pin. I had to press mine out.
