matching plow for 48 M
I have an unused, still has the blue paint and decals on a super Chief, IH 3-16 mounted plow if you have a 3pt. Will sell it cheap. In South Dakota.
Gordo
Back in the day when the M was a farm's "big" tractor, you would typically pull a 3-bottom plow to cover the most ground you could in a day at maximum efficiency.
Now that these tractors are 60 years old maybe you should consider pulling a little less than maximum load?
If you can find a 3-bottom plow that's not all worn out, by all means go for it, but don't pass up a good 2-bottom plow.
My #70 3-16" just left with it's new owner today... Pulled it with my '50 M for the past couple of years... Took 3 wheel weights a side on new 15.5 x 38's to power out before spinning.
Be aware that if you plan to buy a plow with super chief's "cheap" with the plans to rebuild.. It'll cost you a couple hundred a bottom if you replace everything bolted to the frog... That's using a Weise moldboard... IH Moldboards are almost $200 ea... I'm just about to rebuild my 412 16"...
