seals for 400 Hydraulic pump
SDE
The numbers are 994942 and 994842. I called the dealer and they could not find these numbers. They say to bring it down and they will find something for me. I took the pump apart to see if it was in good shape before I install it on the tractor.
I bought this used pump at a dealship auction. Everything looks good, shafts don't show any wear, seals look good too, so should I just put it back together or am I dealing with a inexperienced service man?
Thank you
SDE
I went to the dealer yesterday. The seals and o-rings come in a kit, which is not available anymore. I am going to clean it up and put it back together. If I have a problem with it, I will repost later.
Thank you
Steve
check various bearing houses and hydraulic shops. More than likely if the seals ever go out you can find something through them.
Hoping you would talk to me I have all the separate part numbers for all o'rings and shaft seals for both thompson and pesco pumps. I went through this same run around before with CIH parts people.The numbers I have are up to date with CIH. If email not your thing leave message on my cell #(608)341-6066 I will return your call hate see you put it together all seals and o'rings. Scott
