my 200 leaks oil
kuntryboy
my 200 is leaking oil in the rear. it appears to be coming from the break cover. it falls on the yoke of the fast hitch. there doesn't seem to be anywhere else it could be from. is there anything other than a seal inside? does the cover have a gasket between the cover and the transmission housing? any help is gratefully appreciated.
Check caseih.com for a parts breakdown. The leak is pretty easy to fix, and all that is needed is taking it apart. Photo each stage. JimN
