47 M seals on imput shaftcountershaft-Need Help
Jw-Tc
We bought both new seals at the dealer and they are slightly loose inside the aluminum housing, what do we need to do.Thank You
They had to give you the wrong seals. They shoould be a light press fit into the bore, so smaller is just wrong. take your oil seal to a bearing shop to get the correct ones. If the dealer remains off base, tag him out. JimN
JimN's advice is right on - you were sold the wrong seals!
The new seal will be about 1/2 the THICKNESS of the original - this is OK. However the correct new seal will be a light press fit into the seal retainer.
I believe you are talking about the oil seals on the front of the transmission.
there should not be any aluminum housing that I am aware of.
the top seal on the input shaft is part# 43359D
the bottom seal that drives the belly pump is part# 50839D
