M in Sask
Hello Just finnished this tractor on Dec. 24 .My daughter is getting married next Oct and wanted engagement pics. with some of my old tractors I had redone a Allis B earlier this winter so I wanted to get the Farmall done because of similar size and the fall colors . MM. model R is next for the shop .
Bolt pattern is 6x6.5 on the A and B farmalls. Center hole is 4.75. Allis chalmbers b is also a 6 bolt hub, not sure what pattern is.
thank you, thank you THANK YOU!!! cgtractor. i have to find a set of rear wheels for the Avery im working on. and had no idea what other makes/models i could use for reference
