460 Diesel Injector leaking
Does anyone have a recommendation on what to do to stop the leak. There is a large tap / plug on the bottom that is leaking. How can I fix this.
Also I have an injector that is leaking. All fittings are tight. Any recommendations?
Pull the injector and pre cup, clean all the mating sufaces and install new seals. There are 2 metal and one rubber o ring.
