Mike-- here are the settings for the IH Model R I 1/4 inch carburetor. Open the fuel adjusting screw on top of the fuel bowl one and one half turns and the idle mixture adjustment screw underneath the carburetor about two and one half turns. Prime, choke, and crank. I belted mine to a JD60 and let that big horse do the work. Before I close, what part of NM are you located? I grew up on a ranch in the San Luis Valley in southern Co.
Forgot to add-- there are about 5 or 6 different carburetors for the Regular, but I think these adjustments will give you a starting point.
