Who sells wheel and drawbar hardware?
Finally getting back to making progress on the LP Super M and noticed the bolts that clamp the wheel to the axle are not in good shape, also the bolts that hold the drawbar mount on the axle housing are not great either. I haven't had any luck searching for new ones but I haven't check the dealer yet. Any aftermarket sources for this stuff?
Not likely you will find those at any general hardware store, and if you do find the proper grade and length, most likely the threaded portion will not be the correct length. Your local Case-IH dealer will probably have them. Might be pricey, but they will be correct.
I might could wing it on the drawbar mounts, but the wheel bolts are special since the head is smaller than SAE for that size bolt.
I made new drawbar bolts to fit around the axle housing by buying gade 8 bolts at Ace Hardware and the grindng the head down to fit the U channel. Worked great. Wheel bolts another question, never had a problem. Henry
I havent owned an H in awhile but I know that I bought wheel bolts at my local autoparts store that matched them up.
