Light switch on 656
Hello,
I think the light switch on my 656 is going bad. Been mowing some at night and the lighs begin to flicker and eventually go out. I turn off the switch, then turn it back on and they are fine. Are the switches still available from IH? Anything else sound like a possible cause?
Thanks,
YC
check your fuse when they go out. It might be red hot, with melted solder, and when it cools the lights will work again. Even with a new switch ours did that until i cleaned up the grounds, and broke down and rewired the tractor.
karl f
p.s. i'm for relays and redundant ground wires on tractor lights. requires some custom wiring :)
Having too many lights on the switch will cause it to burn out. Three is about all these switches can handle comfortably, but a 656 will generally have at least 5 lights, more if you added additional lights to the rear of the tractor for mowing.
