Anthony SW MO
New User
My H has a bad knocking noise from the belly. It does it in all gears including neutral. It does go away when pressing the clutch pedal in. In neutral it is noticable to most people but when you are driving I think a deaf person could hear it. Also when in neutral and pulling back on the hydraulics it gets louder. I have pulled both inspection covers off. Everything to me seems loose. This is my first H so I have nothing to compare to as far as the amount of play expected. Are the 3? bolts that hold the joint behind the pump in front of the trans supposed to have a lot of play? Any help would be great. Thanks Anthony
