560-656engine swap
RBG: Direct swap, only difference will be air breather. 560 had oil bath, 656 had dry element. You may have to use 656 flywheel.
You will also need to change the front cover. The 560 mounts on top of the frame. The 656 mounting bolts go through the frame from the side,
