Anonymous-0
So, here goes. Friend let his step-son drive super A in Rain storm. Tractor died and won't start since then. Removed Sediment bowl and cleaned. Checked for Spark on all cyilnders - good to go there. Removed bottom of air breather and replaced with fresh oil. When you choke it after a few cranks gas pours out carb. So I know it is getting gas. If you don't choke it no gas pours out. Only thing I noticed that was wierd is that i had the pre-cleaner jar and head off and it was spitting liquid up are cleaner pipe (before I cleaned breather oil). any suggestions?
