Farmall 400 fh implements
redblood
have the Farmall 400 that my Grandfather bought new along with the 3 bottom plow and disc all fasthitch. I have picked up another plow. One plow has a disconnect point mounting, One has a spring on top of it no disconnect. both are 3 bottoms. I have been trying to find model numbers for these three items with no luck. Can anyone provide me with information to find the model numbers? i plan on repainting them this winter and wanted to put the model numbers back on them so my children will know. I have posetd this same question in the implement alley forum. Thank you in advance.
If the 2 point frame breaks away from plow. It sounds like a # 30. The other may be a variation of the 30 if its 3 bottom. Not sure about it though. They made one with spring on top for utility 300 and 350,# UF 30, they had a bracket for a top link arm though. Saw some other spring loaded on top also for small prong super C and others.
No rectangular beam. A while back someone had a complete listing of equiptment for a C. I was wondering if someone had this style listing for a 400. The #2 plow with out disconnect does look like the one for my C But with big tongs and one more bottom. I beleive its # was 34-f30. Once again thank you.
