Dual for H Farmall
I would say the easies way to do that would be to fine another set of wheels centers and clamp and just turn the inside one dished in and the other side one dished out
Not much. Even with the inner wheels dished in, they have to be slid all the way in to have enough axle for the outer wheel centers.
If you're a bit if a "wide load" you might have brush burn on your buttocks by the end of a long day tractoring.
IMHO, clamp-on duals are much more practical. All you have are the rims, spacer bands for between the rims, and 3-4 clamps per wheel.
Yes clamp-ons would leave space around the operators platform and be less work to take on and off. Like the others said using two sets of casts and rims really narrow the space around the platform, that is unless you have the longer axles that were availible for the H. Than it wouldnt be so bad.
