is my H one of the last ones?
Anonymous-0
I have a farmall H and the serial number is 391721 but i have looked in my book and it says that they only made 390,500 of them what is the actual production number?...is it rare or just a regular H?...this tractor does have a set of super H rear rims and IH disc brakes and also a super H drawbar...tell me what you think
Guy Fay's Data Book says they went to 391730. So, you're in the range and you have a very late H. Neat. mike
Tim: Do you know whether you have C-152 or C-164 engine? The IH disc brakes don't surprise me, a few of those came as early as 51. As for the drawbar, my dad's 51 H had the same drawbar as his 55 Farmall 300, it also had the same brakes as the 300.
I also suspect his H may have had C-164 engine as it was very close to 300 on power. I can remember using disk and field cultivator on both tractors, and in my opinion, the only difference was TA.
Your tractor definitely will be in the last few hundred H built, might even be closer.
