we recently picked up a SC. It has an extra hyrdraulic reservoir, an adaptor block, and a Gressen valve. The extra reservoir is plumbed to give more capacity to the tractor's system. The valve has only one work port hooked to a hose, the other is blocked off. The valve looks really simple, so i do not think it has relief or internal valving to dump for single acting use. Also i assume the block comes before the factory relief valve. With my observations and assumptions it appears that using the valve will dead head the pump.
Does anyone have more information on the Gressen valve and the adapter block? if i'm right, i'll have to get a relief valve or a different valve set with a relief.
thanks
karl f
thanks
karl f
