CenTexFarmall
Previously, with D Slater's help, we were able to figure out that I had a replacement block on a '52 M. Has "C-248" cast showing displacement, also casting date is 10-27-E which if I understand correctly translates to 1959. Is that correct?
Big questions is does anyone know (without a teardown) if these replacement blocks were cast to use regular M sleeves or were the bores cast bigger and used thicker sleeves to make it a 248?
