Farmall exhaust lift
Davset
Found a Farmall B with pneumatic lift-all, at least most of it. I"d like to get it fixed up at least for show, but I"m missing the cable pipe and both pulley brackets & pulleys. Anyone know where I might find one? Yes, I could probably make something that will work, but if there"s one around somewhere that can be saved from the scrapman, it would be much better.
Thanks.
Not very close up but here is a picture of a cultivater with exhaust lift from RPRU.
The exhaust was use to build up pressure to lift implements.
Notice the big cylinder beside the front of the tractor. There is a cable over the top of it for the lifting.
Yea, that"s it.
The parts I"m missing are the pulley (and bracket) at the top of the cylinder, the attached pipe, and the pulley (and bracket) at the bottom of the pipe.
Anybody got one and would like to part with it?
