460 Utility tel a depth
I finally found a section on the teladepth in the 460 IT manual and it says the unit should go "off pressure at each end of the 90 degree lever range. Mine isn;t going off pressure. I removed the guard so I could move the lever more than 90 degrees and I have pressure through about 140 degrees of movement of the range lever. Anyone have experience with these things? Also the rock shaft lifts if I move the range lever forward and down. Is that correct or do I have the hoses reversed? Thanks in advance
Gary: Back when these tractors were new, you were involved in law inforcement. Most of us trying to make a 340, 460 or 560 draft control work were on the fringe of breaking the law, well at least uttering 4 letter words. When you get it figured out, then you can tell the rest of us.
