I have a delco 10 SI, and it used to charge by the one wire method, then it stopped working all of a sudden. Took it off and brought it to be checked turns out that it is fine. put it back on and the only way that i can get it charge is by grounding out the "R" terminal. then it pegs the amp meter right out... charges 14 volts. but if i shut it off then do it again it will not self excite i have to ground out that terminal for a second again. Do i have a bad ground to the tractor thats all i can thing of I have 3 other tractors set up like this and they all work fine, not sure whats up with this one though....
Thanks for the advice!!
Andrew
Andrew
