Farmall H steering column
ryanroth
Hello everyone-- This is probably a very simple project, but I want to remove the steering column on my 44" H and have never done it before. Any oops type things I need to know before I start. Any pointers would be beneficial. Thanks Ryan
There are three parts to the systen.
A steering wheel and support with shaft running to the hood.
the front shaft, with U joint, and worm gear, and the Bolster, A large casting with a gear box on top, and a vertical shaft running through it that holds the wheels.
What are you taking apart? caseih.com search for paets has the diagrams of parts, JimN
