O14 engine start up
Anonymous-0
Well my long term O14 project is nearing start up time.The engine was completely overhauled,new bearings sleeves piston,head was gone thru.this engine has been siting without oil init for a couple of years in the shop.Is there a easy way to prime the oil pump or should I just filler up and go?I have beeh puting a little oil down the jugs from time to time and rolling her over.Any other " should dos at this point?Thanks Chuc K.
Chuck - I've had good luck doing this:
1 - Remove the rocker cover and dump a quart of fresh oil over the rockers and valve stems.
2 - With the plugs out crank the engine until you see the oil pressure gage come off the pin. This tells you the oil pump has primed and the filter canister/oil lines have filled.
3 - Replace the plugs, fire 'er up and enjoy the smoke and noise!
Well, if you have a starter on it, Bobs suggestions are good. On my F14, I Pulled it in 3rd gear real slow and let the pressure come up, the nstopped and turned on the gas, set the mag and throttle, and pulled it a few feet and she fired off.
