It"s finally warm enough here in SW Michigan to start planning projects.
This morning I replaced a rotted bed in a 4x8 small trailer.
When that was finished I looked into the hyd leak on my 300U control valve.
I pulled the plug where you see the bubbles to see if there was a bad o-ring. There is no o-ring, it is a 3/4 pipe plug.
QUESTION: Is it ok to use regular white plastic thread tape in the hydro system. Or will it dissolve and cause problems.
Thanks,
Dell
Thanks,
Dell
