I'm try to locate source H farmall disk brake
Anonymous-0
My H farmall had disk brakes and I've been told that there was an update kit to convert from band brake to disk brakes. My disk brake setup is different that super H's. I'm trying to locate a tapered compression spring that goes around the adjustment screw on the inside the brake housing.The the screw points upward out of the housing. Case Ih has retired the spring and the spring on both sides are broken so I don't know what it should look like. Any idea where they can be found?
Dave
Hi Nebraska Cowman,
I found springs today so I should be good to go. thanks for answering my post on YTMag.
It sure is nice for people to help out!
thanks again!
Dave
