Is this block wasted?
Anonymous-0
1950 cub. Engine is stuck. I've been soaking it for about a month. Finally got the head off. Pistons and valves are stuck. While prying on one it broke. The problem is the seat looks horrible and it's part of the block. Can anything be done to save it?
I tried to post a photo. Got it under tractor photos on the left here but I forgot how to get it here.
Unless there is a BIG HOLE inn the block She is fixable . New seats can be installed the block bore the deck resurfaced the line bore on the crank can be trued up . It just takes a few bucks more . But if done correctly it will be better then factory.
Here you go. David..................
