Rookie screwed up already Part III The Happy Ending
Gary- The Rooki
01-30-2003 15:02:51
In our earlier episodes I told of my exploits with my new (to me) 'H' not starting after a battery cable jumped off and sparked when I re-attached it. I got lots of good advice here and started with the easiest ( re-charge the battery) and finally met with success by pulling the starter and letting the bendix pop loose.
YEAH!
Thanks to all who replied,
Gary
P.S. expect to hear alot more questions from me.
wh
01-30-2003 17:41:41
 Re: Rookie screwed up already Part III The Happy Ending in reply to Gary- The Rookie Farmer, 01-30-2003 15:02:51
just refer to it as a "learning curve"!!! wh
Bus Driver
01-30-2003 16:26:36
A single problem is relatively easy to deal with. Essentially, you had 2 problems at the same time. Makes the diagnosis more difficult by several orders of magnitude.
PatM - It ain't a screw up
01-30-2003 15:29:03
unless ya gotta junk the tractor!
williamf
01-30-2003 15:09:23
Every now and then something works out. We'll be right here.
Wm
