400 rear hyd lines
rtb321
does anyone know where i can find a set of factory steel hyd lines that run from the spool valve to the back of the battery box. i'm not having any luck locally
It may be easier to convert to hydraulic hose. The hose will withstand the vibration better too.
Hal
(quoted from post at 05:59:24 03/29/09) It may be easier to convert to hydraulic hose. The hose will withstand the vibration better too.
Hal
there's not alot of room behind the dash, and they need to make a sharp bend at the bottom, i'm not sure how long hose would last, or if there would be room for it.
If there is a sharp bend to make, use hose with FJIC ends and use a 90 degree MJIC x MJIC to turn the hose. JIC also swivel until tight, makes it easy in close quarters.
Charles
also, depending where yours are damaged, you can cut off the damaged part, braze a fitting on, and run hose from there.
karl f
Here's a spare hose I made for my garden tractor using reuseable ends. The swivel nut ends come in straight, 45 & 90 degree elbows. They're the 37 degree JIC fittings. I made new hoses for the Super C that I had when it blew a hose when raising the plow. I changed both hoses.
