Company Logo Shop Now
Re: Old Raceway M-Minor Setback
Zonie
09-29-2002 21:24:01
Sounds to me just about the same as my H was running shortly befor I ended up with a knocking bearing. Check out the rod and main bearing clearances. It's a lot cheaper to replace bearings, and easier than waiting till you have to get the crank turned.
When I overhauled My H I did surface the bottom plate on the oil pump as some otherss have mentioned, by using the plate glass and very fine grit emory cloth, worked great! If you do this make sure you put even pressure over the entire plate.
Good luck,
John
Today's Featured Article - Tractors and Winter - by Staff. Unfortunately, tractors and winter don't mix well. It seems that I can start out with my tractors in great running condition but sometime during the long cold dark winter they quickly revert to the lawn-art category. The lack of running, cold weather, and admitted neglect all take their toll on a machine. If you are lucky enough to not need your tractors during the winter months you can perform a few simple maintenance items to winterize and come spring have them going by reversing the process. If you need your tractor in ready-to-run condition (like that ... [Read Article]
Latest Ad: I HAVE A FRIEND THAT NEEDS A GOOD STRAIGHT NOSE CONE FOR FARMALL C LET ME KNOW WHAT YOU HAVE [More Ads]
Copyright © 1997-2020 Yesterday's Tractor Co.
