Re: 560 DIESEL
ronohio
09-27-2002 14:21:55
Our 560 had a skip, we replaced an injector ($250), still skipped, took it to the dealer. He replaced a bad rocker arm and push rod. He split the tractor to do it. Said it was easier than removing the fuel tank. Bill $550.
Hugh MacKay
09-28-2002 13:48:50
 Re: Re: 560 DIESEL in reply to ronohio, 09-27-2002 14:21:55
That fuel tank can't be that hard to remove, is it? I had to change a rocker arm and push rod in my 656D. Mine was near front of engine, so no problem with fuel tank. My memory is a bit fuzzy on this, fuel tanks on 560 and 656 both went ahead over engine aprox. 2 cylinders, right or wrong. I don't know that the tanks are the same but close. They both hold 33 US gal. I would think most any wrenching guy on here would be quite willing to remove tank and put it back on for half the $550. Your probably talking US dollars, I would do it for half the $550 in Canadian money, 656 or 560 either one.
