Farmall a
DON HILL
09-12-2002 18:08:57
CAN YOU PUT HYDRAULIC LIFT ON THIS TRACTOR? A BLADE? A BUSHHOG MOWER?
Steven@nd
09-13-2002 07:31:09
 Re: farmall a in reply to DON HILL, 09-12-2002 18:08:57
See link for pics. We use ours to run the sickle mower and also do some cultivating with a disc. I think it is about a 4gpm pump. You can get them from northern tool and equipment for around $100.
Steven
David A
09-13-2002 18:14:29
 Re: Re: farmall a in reply to Steven@nd, 09-13-2002 07:31:09
Looks like you have the left rear wheel dished out and the right dished in. Why's that? Is there a weight on the left?
David
Steven@nd
09-13-2002 19:38:42
 Re: Re: Re: farmall a in reply to David A, 09-13-2002 18:14:29
Here is the simple answer: it was that way when we got it! Actually if you think about it, this would provide the best stability as the wheels on the engine side are out farther, making it less likely to tip. It has been used as a haying tractor, mowing and raking in steep ditches so safety has been a concern. I guarantee you it won't tip over the way it is, I have slid sideways down quite a few ditches.
No weights on that side that I know of.
Steven
gene b
09-13-2002 04:07:36
you can run a CHAR-LYNN unit of the pto and go from there
DON HILL
09-13-2002 04:57:48
 Re: Re: farmall a in reply to gene b, 09-13-2002 04:07:36
THANKS GENE> NOW TELL ME WHAT AND WHERE TO FIND A CHAR_LYNN
EZ
09-12-2002 18:57:01
If your A has no hydraulics like the SA, you can always build your own hydraulic lift. I am lifting a front blade on mine with a vehicle "power steering pump" as a hydraulic unit, works great.
Check out: Link for another idea.
