Re: Super C
bcPA
08-28-2002 09:14:52
I agree withDhuth but would add take a soft wire and slowly raise the piston to top dead center with all plugs out so as to make turnong eng easy. You will be able to feel the piston move up and start back down. In the dark with a flash light you may even be able to see the piston moving thru the plug hole. After getting the crank turned to top dead center I would add my own marks to the front crank pulley andthe eng block or housing with a paint stick or engraving tool. Put the marks where it is most convenient for you to see and to put them on the parts with what ever you decide to use.
