Company Logo Shop Now
Re: wheel weights, inside or out?
Bill Smith
08-07-2002 22:22:04
Your tractor is more stable with caste iron centers of wheel dished out and slid out to the end of axle and with wheel weights mounted on the outside of wheels. Any other way will bring center of gravity closer to center of tractor, loosing stability. Mounting weights on inside of wheel doesn't seem like much difference but take a 15 pound sledge hammer and hold it next to your body and then hold it with your arm fully exstended outwards. It is alot harder to hold up with arms extended outwards. Same thing apply's when adding weight to the axle. It is alot harder to raise that 100 lb wheel weight at the end of the axle than it is right up close to the tractor. That is what gives you stability. If you are looking for stability I would mount both wheel weights to the outside of wheel.
Today's Featured Article - Tractors and Winter - by Staff. Unfortunately, tractors and winter don't mix well. It seems that I can start out with my tractors in great running condition but sometime during the long cold dark winter they quickly revert to the lawn-art category. The lack of running, cold weather, and admitted neglect all take their toll on a machine. If you are lucky enough to not need your tractors during the winter months you can perform a few simple maintenance items to winterize and come spring have them going by reversing the process. If you need your tractor in ready-to-run condition (like that ... [Read Article]
Latest Ad: I HAVE A FRIEND THAT NEEDS A GOOD STRAIGHT NOSE CONE FOR FARMALL C LET ME KNOW WHAT YOU HAVE [More Ads]
Copyright © 1997-2020 Yesterday's Tractor Co.
