Secotr gear and worm gear on M
John S.
07-25-2002 15:12:16
I just rebuilt the front end on my Farmall M and I still have quite a bit of play between the worm gear and sector gear. Is there anywhere to buy these gears new? If so about how much are they? If I could get the play out of these the front end would be wobble free. With the tractor jacked up I can turn the front wheels back and forth a couple of inches without moving the worm gear. thanks in advance.
Justin
07-26-2002 19:43:21
 Re: secotr gear and worm gear on M in reply to John S., 07-25-2002 15:12:16
The worm and sector are still available from case.
The sector is around $225 and the worm runs $450-500
John S.
07-26-2002 06:10:24
The bearings are new and tght and the bushings are new but the upper part of the shaft under the top bushing was pretty wore and has a little bit of play in it side to side. Thanks for the replys.
Andy Martin
07-25-2002 20:45:45
Assuming all the bearings are tight, try a salvage yard. I have several M's and have never had a problem with worn gears. Lots of old M's have perfectly good worm and sector gears and you should be able to get a good used set.
John S.
07-26-2002 08:32:48
 Re: Re: secotr gear and worm gear on M in reply to Andy Martin, 07-25-2002 20:45:45
I was reading a few other posts in the archives and seen a lot of you had to pull your sector gear of the shaft. I can pull mine off with my fingers after I take the nut off. There is a washer under it. Why does mine not press down on my shaft? Is there any way to get rid of the slop in the upper part of the shaft between the shaft and the bushing? Thanks
John S.
07-25-2002 19:36:41
This is only the half gear. I thiought maybe someone might reproduce it.
REM Mo.
07-25-2002 18:22:59
Usually the sector gear on theese is a full round gear and you can take it off and turn it a half turn and put it back on. This gives you an unworn area against the worm gear when straight ahead and the worm usually isn't worn enough but what this will pretty well tighten things up.
Bryce Andreasen
07-25-2002 15:29:41
normally, there is play in the steering drive case. but if its very bad, there is some company that will make exact replicas of farmall gears and parts.
