Are frt bolster shaft bushings available for an H?
Roger
07-22-2002 18:58:31
Help! I snapped the frt bolster shaft off just above the thrust brg.I have the brg and its still good but the bronze bushing and oil seal below the worm gear box are shot.The lower bushing is wore through.Any help like availability and part numbers would be appreciated.
RPM
07-23-2002 12:14:06
 Re: Are frt bolster shaft bushings available for an H? in reply to Roger, 07-22-2002 18:58:31
Parts are still available from CNH, lower bushing 49658DAR $33, upper 43805DR $24, upper seal 389445R91 $10, this was a common failure on H/SH/300/350, just not beefy enough, M/SM/400/450 would hardly ever break, lot more massive part.
Mike ISW
07-22-2002 19:30:59
Your local CIH dealer should have on hand or will be able to get.
Dick Davis
07-23-2002 02:40:57
 Re: Re: Are frt bolster shaft bushings available for an H? in reply to Mike ISW, 07-22-2002 19:30:59
So Roger, how does one snap off the bolster shaft above the thrust bearing? there's got to be a story there!
