Super MD
THR
07-04-2002 13:01:41
What do ya think?its pretty much all there with only some minor things missing.Tires are good.One is new,cant fiqure out why,the engine is froze solid.How much you reckon its worth?Parts tractor?!
Roger
07-04-2002 19:14:37
 Re: Super MD in reply to THR, 07-04-2002 13:01:41
Last year I completed the total restoration of a Farmall MD. You are not kidding when you say it is expensive to rebuild one of those tractors. You can easily put $5000 into the engine and injector pump/injectors and that is if there isn't a cracked head. I ended up putting more than $8000 into the total rebuild (I must be nuts), but when I was done I would never part with it. That IH diesel engine is a mechanical marvel. It was a challenging, but fun project. Roger
Red Rider
07-04-2002 21:09:35
 Re: Re: Super MD in reply to Roger, 07-04-2002 19:14:37
I hear ya friend. I did the same thing with a 600D. Once you start you get deeper and deeper. Then you get to the point that you've got so much into the restoration that your commited to finish it. I to have over $7000 in to the D350 Diesel engine but she runs like a top now. I have two other of these gas start diesels, a 400D and a TD9. I love em and wouldn't part with any of them.
Iowa Will
07-05-2002 15:41:07
 Re: Re: Re: Super MD in reply to Red Rider, 07-04-2002 21:09:35
I own an MD that I bought at my FatherinLaws' sale. He loved the tractor so I kept it in the family. It runs fine but I did have to get the head fixed shortly after I brought it home. I find the gas/diesel configuation interesting but it's a very complex motor. I think it would have been a pain to work in the field since you have to switch to gas and run the bowl dry to shut it off according to the manual. I wish I would have talked to him more about it to hear his stories.
gm
07-04-2002 19:10:35
I would think $500 is the standard price
for a screwed up tractor. If you don't want
it, let me know, I would take it. If you do get it, I can sell you a good head, pistons/sleeves, ...
-Greg
Poppin' Johnny
07-04-2002 18:32:00
Sod may be a little too low, but you have to realize what that bad engine really is. A rebuilt engine is about $5000. You read that right.
JD
07-04-2002 16:37:55
SOD, you are an IDIOT.
sod
07-04-2002 17:47:10
 Re: Re: Super MD in reply to JD, 07-04-2002 16:37:55
Look at the picture. There is no exhaust stack...
Those valves are rusted and probably pitted. (three valves per cyl.) New sleeves, pistons, rings, bearings, cam and cam bearings. As long as it's apart, put in a new TA and clutch. How about the gearbox? I'll bet the auctioneers love you. Do you raise your own bid?
Keep your comments confined to the civil, please.
good luck
sod
sod
07-04-2002 17:36:14
sticks and stones, pal.
What's wrong with offering a C note and bargaining from there? It's obvious it hasn't been moved for some time, and even an idiot like me knows how much those gas/diesels cost to refurbish. Sometimes people jump to conclusions.
I think this is one of those cases. You are forgiven. It's not like I was saying anything bad about Farmalls, you understand, I have one myself and love it. good luck
sod
sod
07-04-2002 13:44:45
$100 good luck. That should be a fun one. It may cost some dough, but you would have a nice one! sod
TP from Central PA
07-04-2002 15:17:50
 Re: Re: Super MD in reply to sod, 07-04-2002 13:44:45
Tell you what, if you get it for $100, I give you a $150 to haul it to my place ;-) Looks like a good find!!!!
TNR
07-04-2002 13:02:37
Give me a minute!Cant get the pic up for some reason.
Maybe now!
07-04-2002 13:04:35
 Re: Re: Super MD in reply to TNR, 07-04-2002 13:02:37
:D
Dick
07-05-2002 19:54:18
 Re: Re: Re: Super MD in reply to Maybe now!, 07-04-2002 13:04:35
It looks like it maybe a good project to tackle. If you get freed up and it turns out to be a real lemon, then you could get your money back in "parting her out". My 2 cents.
