H Bolster
Bill(Tx)
08-16-1999 09:08:11
Should there be any play up and down in the bolster pivot shaft when the tractor is raised and weight taken off of the wheels? I was thinking this may be a bearing problem, although I can't hear or feel any grinding in the thrust bearing. The play appears to be about 1/2".
leon
08-16-1999 09:27:51
 Re: H Bolster in reply to Bill(Tx), 08-16-1999 09:08:11
Bill,
I had the post just before yours, and as I said, I just finished a restoration of a 47 H. I had the same situation but had about a quarter inch of vertical play. I had torn the entire tractor completely apart so it was easy to see where the problem was. At some time the tractor's bolster thrust bearing had gone out. According to an old timer friend which was a former IH mechanic, this happened often. This problem is not noticable until the tractor is jacked up. There is not supposed to be any play other than a small amount to keep the gear from wearing on the bolster casting. Mine had worn enough that I had to have the shaft built up at the bearing seat.
Hope this helps
Leon
Bill(Tx)
08-16-1999 10:19:59
 Re: Re: H Bolster in reply to leon, 08-16-1999 09:27:51
Thanks, now I'll add another bearing to a new parts list that is getting really long. I've got a parts H to obtain a bolster pivot shaft if needed.
