Re: Finding BN parts-
Haas
07-01-2002 13:44:36
The B only came with the tricycle style front axle. I gather yours has a wide front. You can't cut the wide front axle down and make a tricycle out of it. Your best bet is to find a salvage yard and locate a B front bolster and pedestal. If someone put an A front on your tractor, then the steering gear and steering shafts will be wrong too, so you'll have to get all that from the salvage yard too. Note that A Farmall C steering gear is similar to the B, but will not work on the B. The steering shaft comes out on the opposite side.
William Ransom
07-01-2002 14:18:45
 Re: Re: Finding BN parts- in reply to Haas, 07-01-2002 13:44:36
I think he meant rear axles. A BN has shorter rear axles than a B.
Fred
07-01-2002 18:56:17
 Re: Re: Re: Finding BN parts- in reply to William Ransom, 07-01-2002 14:18:45
The left axle is much longer than the A's, the right side might be the same.
