Farmall Regular
Author |
Jeff
06-28-2002 20:52:37
I was told I was getting a F-20, but after looking at the exhaust and steering gears, it appears to be a regular. Where would I find the serial number on it? Thanks.
Ken Williams
06-29-2002 12:10:02
Re: Farmall Regular in reply to Jeff, 06-28-2002 20:52:37
Jeff,You should be able to find it on the tool box, under the fuel tank, on a tag. If that is missing, it should be stamped on the left frame rail, close to the radiator mounts, unless it is a very early Regular. If that is the case, you will have to use the engine serial number, to approximate the age. Happy tractoring, Ken
Jeff
06-30-2002 19:12:49
Re: Re: Farmall Regular in reply to Ken Williams, 06-29-2002 12:10:02
Ken, Thanks. I have a couple of questions; I usually don't have trouble with serial numbers, because they're easy to read on my other tractors, but this one's border line: The tag on the tool box is gone, but I found the number 103772N on top of the left rail just before the radiator mount. I'm assuming this is a part number, not a serial number, but I wanted to pass it by you. On the left front of the block I found the serial number OC1045, and what appears to be a 5, 8, or 9 after the 5. I assume it's actually QC, and that the number is 1045 since my "Farmall Tractors" book shows the QC numbers stopping at 1568 before switching to T1569. Am I correct in saying it is QC1045? Thank you.
Ken Williams
06-30-2002 19:38:05
Re: Re: Re: Farmall Regular in reply to Jeff, 06-30-2002 19:12:49
Jeff, It appears to me that you have a 1930 Farmall Regular Narrow Tread. The number up on the frame rail should be correct. You should be able to tell if the number was stamped or cast, in the frame rail. The correct prefix, on the engine serial is "OC", but the engine serial number, should be larger than the tractor serial number. If you can, look at other Regular or F-20 tractors, and measure their axle width, as compared to yours. A narrow tread Regular, has a much narrower rear axle, and is much more desireable, congratulations. I hope this helps you. Happy Tractoring, Ken
Jeff
07-01-2002 05:09:47
Re: Re: Re: Re: Farmall Regular in reply to Ken Williams, 06-30-2002 19:38:05
Ken, I measured the rear tires center to center, and it was 6'6". Is this a narrow tread?
Ken Williams
07-02-2002 08:40:19
Re: Re: Re: Re: Re: Farmall Regular in reply to Jeff, 07-01-2002 05:09:47
Jeff, yes, I would say that it is. Ken
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Old Abe is Still Making Hay - by Jeremy Sweeten. Things have changed a bit since my last article. I am now almost finished graduate school at Purdue University. I am still in Agronomy, but specializing in hay and forages. My wife has survived two years of marriage to a part-time farmer. The equipment line up has changed a bit too. The DC has retired to
... [Read Article]
Latest Ad:
JD 420 -430 crawler 3 pt. center link 3 parts
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
