1086/rear axle seal leaking!
D estey
06-07-2002 04:13:50
can anyone tell me how to repair this leak? do i just pull the tire and rim off then remove the cover and replace the o-ring&seal or is there more to it ? any info will be helpfull thank you!
RPM
06-07-2002 06:16:47
 Re: 1086/rear axle seal leaking! in reply to D estey, 06-07-2002 04:13:50
Just as you describe, remove wheel, then axle cap, take a look at bearing, could be starting to fail, inner bearing also. Inner tougher to fix, remove housing, while you have gone this far to fix outer it would be wise to check it out.
RPM
06-07-2002 06:01:28
D estey
06-08-2002 04:12:16
 Re: Re: 1086/rear axle seal leaking! in reply to RPM, 06-07-2002 06:01:28
thank you for all your replies! this site is very helpfull!
